TwinTurbo.NET: Nissan 300ZX forum - Same problem here, using a straight edge shows the pulley
Turbodog (CT)
on April 25, 2014 at 5:20 PM
One thing I noticed about the NA pump is the mounting hole.
posted by rcmadness
on April 25, 2014 at 12:34 PM
Is not squared with the crank pulley as you described on yours. I'm going to try shimming between the block and mounting bracket. Seems to be in the right location it's just a little twisted.
Pic Hooering
ZaXxon
08:43:48 04/25/14
Power steering belt losing ribs?
MixManMash
09:35:52 04/25/14
Looks like your running a NA pump
Boosted1
10:32:28 04/25/14
Id bet your pulley is on backwards...
eriksu9
10:36:05 04/25/14
Did you install the NA PS pump bracket with the NA pump?
vorpalZ
11:37:04 04/25/14
Yes, and the correct 4 rib pulley. (n/m)
ZaXxon
11:49:04 04/25/14
Nice. More info on the battery mounting plz.
StramanVerTT(GA)
11:44:33 04/25/14
Braille mount for the battery using Rivnuts. (n/m)
ZaXxon
11:50:15 04/25/14
rcmadness
12:34:54 04/25/14
Mine has never come completely off.
ZaXxon
12:55:30 04/25/14
Have an NA, have the same PS belt problem
rjp288524
12:57:29 04/25/14
Then maybe the answer is to shim the pulley on the shaft. (n/m)
ZaXxon
12:58:35 04/25/14
Same problem here, using a straight edge shows the pulley -
Turbodog (CT)
17:20:58 04/25/14
